I drew this but I'm sure its not 100% correct.
WhiteHendrix gave me info / ideas. Thanks
I'm trying to troubleshoot aka "Hot Wire" my ignition system. I'm pretty sure its my key-lock cylinder. It has been doing the same thing for a long time. You put the key in, turn it to run, and NOTHING! No dash lights! But if you turn the key ALL the way counter-clockwise and lock the handlebars the brake light comes on. HMMMMMMM......... now that I think about it, it sounds like my white and brown wires are not connecting!!
If I jump white + brown together the ignition system and dash lights will Always be on correct? I would need a switch.
I will also need to connect the white wire (12 volt positive) to around a ~100 ohm resistor then to my grey wire but of course will need a electrical button.
Sorry if I have offended anyone for saying "hot wire" as we all hate thieves (and bikes that are bitches
