Hi there;
Any idea if there is some-one who can repair the guide where the needles goes,my needles are getting stucks at all times overflowning the carbs, Iam really fed up with this problem,can NOT find the solution.
Thank for your help
where are you located? In what condition are the "guides"?
Sounds like you need to replace your float needles and seats. A common repair for fuel overflowing out of carbs. If the carbs are dirty or gunky inside, you may want to disassemble and thoroughly clean them while your at it.
You might be better getting a used Carb.
The Seat is part of the Carb body on your Model as you've probably realized which is a pain as it can't be replaced like a conventional one.
