I'm in the process of redoing my wife's EX250. I got everything back together, and took it for a test ride. All went well except I have an oil leak from the side of the cylinders. It looks as if a small frost plug or something went into the hole but fell out. Can anyone post what should be in that hole? Can I just tap it and put a bolt in there? Any help would be great.
Thanks.
i think that hole is the coolant boil-over, I had a leaky coolant hose and coolant was leaking from there when I took it for a long ride. Repaired the hose and the leak stopped. The oil leak is probably just coming through at that spot. Otherwise that hole is there for a reason and probably shouldn't be closed up with a screw.
