Does the crankshaft on 03-04 636's have a timing mark on them that is not visible unless you take the engine apart because my crank moved a hair past 1-4 top dead center while doing a valve adjustment. I myself believe that the bottom crank sprocket does not have a timing mark other then the 1-4 2-3 that you see when you take the cover off, the main timing is your intake-exhaust cams? anyone familiar with the timing on these engines.
Is it possible for the bottom crank to jump a tooth and mess the whole timing up? Once again Im pretty sure the top exhaust-intake cam timing is the main thing here and the bottom sprocket is only a problem if the cam chain was not even on it.
