The front sprocket speed will never change as it's connected to the output shaft. The speed of the rear wheel changes because of the different ratio affecting actual vs indicated speed.Originally posted by tomc
Doesn't the speedo pick up off a small "patch" on the sprocket. Even though the sprocket is smaller, if that "patch" is at the same distance from center as the old it would read right on.
