Thanks GR for the review. I ordered the kit from Greece last week and it should be getting here this week!
I already have the tank off awaiting it to be in my mailbox. I had to clean the air filter anyway so now I'm just playing the waiting game!
Cool, I hope it's going to work good for the both of you so that I won't have to avoid any tomatoes thrown at meOn order. Wow never realized the differences between the ebay.co.uk and ebay.com sites. Made it a little confusing.
I'll be doing my install this weekend and will check the steps to see if I run into this or not. If so I'll send you a message.Any ideas?
Sounds good, thanks! I removed it because the cable didn't have enough slack for me to unplug the connector. You have to stick a screwdriver in the tab and lift. Only reason you have to remove the connector is to take the tank off.I'll be doing my install this weekend and will check the steps to see if I run into this or not. If so I'll send you a message.
But from reading the instructions not sure why you had to remove that part.
I got mine installed last night. Very easy process.
I am having one issue though...
Very glad to know that you saw improvementSo, I went out for a 30 min ride today. Man it was AMAZING. The throttle felt smoother, only a few backfires. I did also have to adjust my chain so that made the ride much better as well.
If any of you are on the fence about doing it, DO IT! Get the kit that comes with everything (so the FI light doesn't come on). Thanks GR Rider! Here's my bike:
Great, I am glad it worked out for you too my friend!Follow up...
I went for a 2 hour ride yesterday. Bike performed great. Minimal popping more like a light rumble. Throttle felt smooth and the shifting was nice.
Not to mention this was my first long ride with my new bars which also were a marked improvement over the stock.
Time to move on to my next project.
Also, an AMAZING how to guide!OK guys. As promised I've posted my installation notes in the HOW TO section:
http://www.kawiforums.com/how-tos-faqs/312889-how-install-smart-moto-pair-valve-eliminator-kit.html
OK, I have measured the resistance of a pair valve, there was 20 OHM so I decide to install small resistor 20 OHM. It worked fine... for few minutes... and the FI indicator was turned on for good. When I looked for the reason of that, I found my resistor totaly burned. Finaly I have installed pair valve with silicone caps and all is fine for now. So I DON'T RECOMMEND to instal any ordinary resistors instead pair valve.
