Hi All
I was hoping someone can given me an opinion. I brought my ER6F to the garage three weeks ago for the 35KM service. The services covered in the invoice are below (English French translation). Since the service I rode the bike 100km approx and today on the motorway I sense I had a catastrophic event in the engine - hearing lots of metal failing. I personally think its probably linked to their intervention. I wait the feedback of the problem. Looking at the below, would you say that its a strong possibility?
FILTRE A AIR
JOINT VIDANGE
FILTRE A HUILE
NGK BOUGIE
HUILE 4T SYNTHESE FUT
SEAL - OIL , 12X28.55X5
JOINT TORIQUE , 33.2MM
JOINT TORIQUE , CASE - HOUSIN
JOINT MECANIQUE KR250
JOINT TORIQUE , HOUSING
POM MAIN D'OEUVRE
Translated with Google
AIR FILTER
DRAIN GASKET
OIL FILTER
NGK SPARK PLUG
OIL 4T SYNTHESIS FUT
SEAL-OIL , 12X28.55X5
O-RING, 33.2MM
O-RING, CASE - HOUSIN
MECHANICAL SEAL KR250
O-RING, HOUSING
Labour
Thanks
Darren
FILTRE A AIR
JOINT VIDANGE
FILTRE A HUILE
NGK BOUGIE
POM MAIN D'OEUVRE
AIR FILTER
DRAIN GASKET
OIL FILTER
NGK SPARK PLUG
O-RING, 33.2MM
O-RING, HOUSING
Labour
Thanks
Darren
