pretty easy, all it is is 4 bolts, and 2 pins.
circled in red are 4 bolts, 8mm AF, undo them. circled in yellow are 2 pins, to remove them push the centre of it then remove them and the plastic surround aswell.
the whole headlight should then just slide forward. i changed my parker clearance lights to 5 smd blue leds while i had mine off, ill prob do a hid conversion one day.
i will accept no responsibility if you stuff it up some how
Looks neat with the blue LEDs. Too bad they'd pull you over in my area.
