Hi
just wondering whether anyone has had a similar issue?
Fault Code 12 came up. Today I stripped the bike down and was kinda hoping I’d find a split in the breather hose running from the sensor to the throttle body (as this was a possible cause someone mentioned on YouTube). But nope, hose seemed fine.
I back probed the sensor and got an input reading of 5v that seems to be inline with the specs in my Haynes manual. However, the output reading was also 5v. Haynes says this should be a lower reading between 3.8 & 4.2v they suggest replacing the sensor if this is the case.
Before I pay for a new one, just thought I’d ask on here for any advice, maybe someone else experienced same issue?
symptoms I’ve experienced were EML / rough idle / Backfire with occasional purple flames out of the exhaust / felt a little lumpy through acceleration prior to the EML showing up on the dash
All the Best
Nate
All the Best
Nate
