I recently ordered a yoshimura carbon fiber exhaust which includes the mid-pipe(elbow). Is installing it pretty straight forward?? Just bolt it on the the oem header, is there a gasket required between the oem header and yoshi mid-pipe? Should it be tourqued to a certain spec? Is there anything important that I should know about before I do the install? I appreciate your advice.
open up the exhaust instructions and look to see if they send you any gaskets. if not, use the one that came with the bike, if any. just bolt it on and go! oh yeah, crank up the bike without a can on! sounds tight!
