what are your current settings? i need to tune mine
Right now since the temperature has really dropped, I have found the most success richening it up to 162's on 1 and 4 and 168's on 3 and 4 and 15mm float height one shim under the clip set at the middle position, 1 1/2 turns out on the pilot screw. When it was still hot here, I found the most power with 2 turns out, 158's on 1 & 4, 162's on 3&4, same float height, same needle clip positions and shims. I don't what the weather is like down there but I can bet it is 5 times better than here!
