1 - 8 of 8 Posts
I hit a false nuetral on my way home today. It was between 3rd and 4th. Its a good thing I was not on the throttle hard. Does this happen? I probably could have shifted harder and I have heard to keep the lever up with your foot until you release the clutch fully but should this happen? I hopr it is not the beginning of something bad. I did a quick search and did not find anything but if it has been covered give me the title to search for.
I have got false nuetral on a '03 B4 especially when on the breaks hard without downshifting also Kawasaki say u can't go past nuetral when stopped but often i find myself flicking between 1st and 2nd trying to find nuetral??
I've had the odd one on the street, but they're very rare. And always my fault. The first time I was at the track I had a few in inoportune times. I was just so new to it (being on the track) and I was so busy doing other stuff (learning the track & breaking points etc, remember your first tme on the track?!...heaven) I was taking the downshift for granted and not being as precise and I usually am on the street sorta thing. It was always during the hard breaking amd downshifting areas. I know it was me though, because after that I got pissed and made sure I was more deliberate and have never had another. When I say deliberate, I mean with the foot not the hand. So I wouldn't worry about it unless it keeps happening.
Thanks guys I have been working on shifting and holding the foot lever in place until clutch is fully released, so far so good
Firm shifts mister. Happens to everybody, but generally it's laziness. Does suck when you're tryin' to keep neck-in-neck with a GSXR750 down the straight though. [V]
Why do you clutch when you race? Plus you can adjust your shifter a little further downward to get a solid firmer upshift. They are adjustable for such a reason!!!
I happend to me several times at Buttonwillow track...it was my fault...like Grunt_99 said I was coming hard into a right hand turn downshifting and busy doing other stuff.....it would scare the shit out of me and I would totally blow the corner...that is the only time it has happened...
1 - 8 of 8 Posts
