I pretty much did the same thing as everyone else did with the cutting of the undertail. Only thing is I left the stock blinkers on it. All you really need is a dremel tool to cut about 90% of the unnecessary shit off the tail, switch turn signals and reverse the license plate bracket. The fender eliminator is the biggest waste of money because it doesn't look much different then our chopped tails. IF you want to spend a $150 you may as well spend a little more and get a real undertail kit. I suggest Texasfairing.com or xtrememotographics.com. Thay definately have the nicest looking ones and they include turn signals.
02zx6r TEAM GREEN!!! Yoshi RS3 carbon, 4 degree ignition advance, factory Jet kit, K & N filter, Kleen system removal
NOw that my engine is done I'm going to concentrate on the body this winter.
