its easy ...first the back seat comes off then there are six push pins you need to take out(push the center of them with a small allen wrench)take the driver seat off with a 10mm then take the upper part of the tail off. take the screw out of the storage and pull that out. remove the four nuts that hold the stock fender on and disconnect the stock blinker and licence plate light wires. i think there are two push pins one the fender also after that the fender should come off. then mount your fender elminator blinker etc etc and put it back together. test all your wiring before you get it back togher though and use lock tight(i didnt and the thing almost fell off)
