1 - 11 of 11 Posts
With the cables removed from the servo all you have to do is keep turning the bike on and off with key.It'll turn a bit every time you do it.DO NOT try and turn the shaft of the servo with pliers,its very easy to strip the internals of the servo.
it wouldn't turn at all when i flicked the ignition.
so i used a bit of force and stripped them :(
i have heard you can run with out the servo by diconecting / cutting a wire??
p.s what a bitch it is to get that servo out, bloody rubber nuts on the bottom do nothing but turn and you can't hold them with any thing wither :S
There should have been a mark on the shaft end, I forget where its suppose to index to be in the right position but i remember I had to do it.. Its in the service manual..
Disconnecting the brown wire with a red tracer on the left ECU connetor will disable the FI light with the exhaust valve servo removed.
Discussion Starter #6
if i desaible the fi light, then it won't tell me of other faults??
can i just remove the servo and live with the light when it comes on?
only reason i wanna remove the servo is because i have brocken the internal cogs, so it's pretty much useless now :(
Discussion Starter #8
ok thanks for that, any one know for sure though??
i was looking at that servo eliminator thingy but can't find the website to order from.
but if it only eliminates the fi light, then i can live with out having to spend $100+ on some thing that does just that :S
i always keep on top of maintenance so i shouldn't require the fi light to tell me of any error and hence can live with it blinking at me all the dam time :D.
so i can just take the servo out then???
If you want to know if the light will come on again just disconnect some other sensor and the light should be on.
1 - 11 of 11 Posts
