Anyone know where I can get the plug for the AIS when you remove it? I purchased the Driven Smog Block-off Plates and it didn't come with the plug to "jump" the connector so the Fuel Injection light comes on.
most on here just jump the terminal with a small length of wire or safety wire and tape it up to it dont come loose.
Do you have a picture or guide for doing that? Anything special I need to get like an Ohm resister, diode, etc?
I was thinking of plugging the AIS hoses back in there and just leaving it connected.
nothing special just use a wire to connect the the two wires in the terminal so in other words the wire is just jumping the two wires in completeing the curcuit no ohm meters or resistors or even diodes are needed just a small length of wire i believe mine was aout an inch long thats it and some electrical tape
