Hi, I have problem with FI light doesn't work tachometer light fine it's work i tried external power source and work fine but i tried everything and i can't light up with using ECU. I measured the BR/R cable to the positive pole and read the 12V value but led won't work please help me.
EDİT: I measured the FI lamp output with a positive pole reading 2V. Where did 10V go?
SOLVED. ECU malfunction. But DFI system work fine.
The implication is that the bulb itself is faulty. Replace it ? The way to test is to borrow a gauge from the same year bike and plug it in.
