1 - 15 of 15 Posts
Finally got the balls to install no cut Shogun frame sliders. The hardest part was deciding to cut your brand new fairing on your brand new $10,000 bike. Took about 1 1/2 hours to install. Had to cut and check like 20 times. I wanted to make sure I didn't over cut. The sliders didn't come with instruction. Can you guys with Shogun check my install to see if it looks right. I put the shorter slider on the right side and the longer slider on the left side with the spacer.
Oppss. I meant cut.:D
Discussion Starter · #7 ·
Thanks. Do you guys keep the passenger peg down or up? I heard they act like frame sliders[?]
Discussion Starter · #11 ·
I wouldn’t recommend the “no cut” frame sliders. From my research, they don't hold up well in crash. I thought about it but figured if you are going to put frame sliders, you might as well do it right and go with the “cut” frame sliders.
DEATH TO THE ISA!!!
no passenger pegs for the win...
my bike is a converted solo bike :D
nice frame sliders tho....i like what you've done to the bike so far my blue 06 636 brother [8D]
good job.
I have the cut Shogun slider's also .
You never see the cut area anyway cause the bike is tilted over when on the side-stand .
1 - 15 of 15 Posts
