The idle bleed screws on float bowl side of the carb next to the inlet to the head. It is on a boss that is about the size of a pencil and has a plug in the end that must be drilled out. The adjustment mostly effects performance below 4,000 rpm. Anything above about 8,000 is controlled by mains jets only.
I just installed a factory stage 1 jet kit on my 01. It runs really good, and i've swapped out jets to find the ones that really give me the best performance. I did everything according to the instructions, except for turning the fuel mixture screws 2 and a half turns out. Where are they in the carbs? The diagrams that i have don't really show an accurate picture of where they are. Also, I have a small flat spot at about 12-13 thousand rpm, what should i do to get rid of that, or will adjustinf fuel mixture screws fix that? I haven't synchronized it yet, but i plan to tomorrow. One more thing, it may be running a bit rich at most all rpm's, how should i lean this out, the reason i say this is that after i got done riding it after installing all of this there was a small amount of black residue in my exhaust tip which makes me wonder if its running rich. Thanks for your help.
Life is short, but sweet for certain...
Do you know what the stock setting is for that screw? As in, how many turns out is it from the factory? I put in bigger jets and raised the clips on the needles and it runs really really good. However, I was just wondering since I haven't adjusted the fuel screws, would this make any difference in performance over what I already have gained? Or would it just run much smoother? I am going to synchronize it today and I'm sure that will probably help some too.
I think the stock setting is two turns out. I would check them by turning them in to see what they were set at from the factory. The air bleeds will only effect idle quality and performace below 4,000 rpm.
