No. Here is an interesting little side note, the forks on the '95 are actually different that those on the '96-'97. They are the same on the outside but different on the inside. I don't think you could get '98 and latter forks to fit unless you swapped the whole front end including wheel and then you would have a problem with the speedo drive.
are just the tubes bent? cause those can be fixed if they're not out too much. just remove the internals and take the tubes to a dealership..some have machines that can straighten them up
