1 - 2 of 2 Posts
Cna someone tell me if a frame from a zx-9r can be re straightened? It has been in an accident and its frame needs some straightening. If possible how much am I looking at spending to get it done? How much for 2001 plastics? How much to fix a crack in the engine case or could I buy a new one? Which would be cheaper?
RE[]DE[]\[]-|-
To be perfectly honest, if the bike was damaged to the extent that A) the frame was bent/cracked; B) The engine case was cracked; and C) The plastics were destroyed, the bike is a toatal loss.
It really is not worth running the risk of riding a bike with a straightened frame. if the work was not absolutely done perfectly, you might very well find your bike come apart under you in a curve under high stress.
As for the engine case, if the crack/hole is in an area that needs to be pressurized (oil line/combustion chamber), it isn't feasible to try and repair it.
Sorry,
BC.
1 - 2 of 2 Posts
