1 - 11 of 11 Posts
I have an 04 636 and I want to upgrade to better braking, i have a rear 05 and 08 wave rotor and I have the 2 05 wave rotors for up front, the question is what do I need to make them fit and where can I get the parts? I know I need 10mm spacers and longer bolts up front I think but what about the rear they look the same size.
Got lime? I do
the rear bolt rite on. nothing needed. just swap it out
need spacers up front, i used grade 8 nuts for spacers, they are exactly 10mm and are dam near perfect. i also used the stock bolts, tried them out by doing heavy breaking and endo's. they have held fine for the past 10,000 + miles
Thanks but is there anywheres i can get spacers?
Stainless steel brake lines, upgraded pads, fluid change. WALA, brake upgrade. My $.02
BTW I love the orange, can't beat owning a rare Kawi.
Got lime? I do
Got lime? I do
yeah i hadn't said it, but rotors are not a brake upgrade, flushing out the old fluid with some synthetic is nice by itself. on the 636, braided lines are nice!
Discussion Starter #7
using the bigger rotors up front should help some shouldn't it?
brake pads with the larger rotors will indeed help you out....but dumping the standard master for a radial unit will help you even more.
+1, I left that that out cuz wasn't sure if the first gen 636's had a radial unit.
Can't he do the caliper upgrade as well??
the nissin calipers would be an awesome upgrade as well...
Discussion Starter #11
can you explain the radial unit, i do have nissin calipers
1 - 11 of 11 Posts
