You can see the proper brake fluid on the reservoir cap. Use any DOT 4 fluid.
You can also use DOT 5.1 fluid. It has a higher boiling point than DOT 4 fluid, which reduces the risk of fluid vaporization and possible brake failure. Although this may matter on the track, you may like DOT 4 fluid just fine on the road.
Do not use DOT 5 fluid. It is silicone-based and not compatible with DOT 4 fluid.
