I was told to try tie down straps, the kind used in a trailer.
Will it work? What do I attach the lower hooks to?
Heard of attaching to the calipers, not to sure about that.
The hole under the forks...the hooks don't fit in well...
Is this do-able?
DO NOT use trailer tyedowns. It can be used but you risk a bad accident if they come loose and catch in the rim or rotor. look up MPS Racing, Schnitz Racing or Brocks racing for lowering straps and the bracket that bolts to the caliper. They are safer and easy as crap to lower and go back to stock. and in case you were wondering it won't hurt you forks
u will need to buy a front end tie down strap made for motorcycles, u can get them for 20 bucks and u will need the lowering brackets as well
