Ok got the stock front sprocket off (easy with an impact) and putting the AFAM one on but I need to know if I reuse or need a new retaining washer? The washer with the teeth that go on the spline and the one side was bent up against the nut.
+1 on above post... you might want to take the rubber rings off the stock sprocket and put them on the AFAM... i DIDNT and noticed a LOT more vibration with the aftermarket
