1 - 18 of 18 Posts
Does anyone know the size of the two Allen keys/bolts that hold the front axle in on a 2001? I see that the one on the left is smaller, there is a tool in the tool kit for this one. The one on the right is a lot larger? Thanks
I don't know on that year, but I do know it has been talked about, so just do a search on front axle, and I'm sure you'll find it. Plus what alternate tool you can use because those sizes aren't common.
22 and 17, but the 22 cant be found anywhere in stores just oredered. i bough the 17 at sears for $7. i used the back part of a spark plug socket as the 22 allen wrench.
"Can't you just leave the axle clamp bolts tightened on one side, and then loosen the axle and pull it out?"
that's what I do...never had a problem yet....
The Kawasaki service manual will also have you remove the pinch bolts only on the right fork, and then remove the axle from the right.
hahahahah
i can honestly say I didn't read the manual and I just tried it becaseu I couldnt find a size 22 hex...
well when i firts tried it it kept moving on me since it was the first time it got broken loose(lock-tite)
loosening bolts on the fork help only when sliding it out.
Discussion Starter #12
Thanks folks. Did a search and found some additional information. The 13/16 plug socket and the tool from the tool kit worked well.
Any suggestions on how to best center/align the front wheel when re-installing?
"Any suggestions on how to best center/align the front wheel when re-installing?"
you dont...if it doesn't align, your are screwed....atleast that's what my manual says on my 02 model...
I imagine your asking what's the easiest way to align the wheel so the axle goes in easy during installation? I usually get someone to hold the wheel up off the ground, and then I put the axle in (a little grease on the axle helps alot).
Like Andy said, if the front wheel isn't aligned after you install it, something is VERY wrong.
yeah I assume he meant the alightment of the wheel between the forks. Some bikes allow you to do this to a degree. But you can't on the ZX-6R. I'm assumming Kawasaki chose not to allow this for some weight savings or to keep costs down.
Discussion Starter #16
I see said the blind man! I was referring to (I assume he meant the alightment of the wheel between the forks). Thanks again guys, I see that there is no adjusting this.
i couldnt find anything to fit those two hex bolts.....so I just used the head on a large bolt, grabbed it with a pair of pliers and gave it hell. Off she came! I wonder how I'm gonna properly torque the wheel w/ a pair of pliers!?
go to a place that sells metal and get 22mm hex rod. a 6" long piece is like 2.00. same w/ the 17. then use some wrenches, and the axle comes right off.
1 - 18 of 18 Posts
