Car is in Delaware
Motor is all new except block and has 40,000 miles on it. Rear end is 9 bolt Borg Warner, with new Ring and Pinion as well as Posi Unit 20,000 miles ago
--350 Chevy Motor, steel crankshaft, new connecting rods, Keith Black hyper pistons
--Air Flow Research 190cc Cylinder Heads, Comp Cams 1.6 Roller Tip rocker arms, K&N Air Filter
--Comp Cams Xtreme Energy Roller Camshaft .495/.502 lift with 1.5 rockers, but with the 1.6 rockers it will be more like .515/.522 lift-----Comp Cams double roller timing chain.
--Holley Stealth Ram Intake, Accell 28 lb/hr fuel injectors, Also has HOLLEY COMMANDER 950 ENGINE MANAGEMENT SYSTEM, which allows you to modify all engine parameters while motor is running...fuel, timing, etc....
--Holley In-Tank 255 gph fuel pump
--Edelbrock exhaust headers, Flowmaster 3 inch exhaust Cat-Back...whole exhaust is 3 inches
--Transmission is T-56 six speed out of 1996 Camaro, it has a B&M Ripper Shifter
--Rear end is 4.10 9 bolt Borg Warner with disc brakes....Entire rear was rebuilt 20,000 miles ago....New ring and pinion, new posi unit and bearings/seals...parts from 9bolt.com
--Front brakes, brake calipers and brake rotors have been replaced, new rear brakes as well
--ASCD Big Block Stinger hood, American Racing Torq Thrust II Aluminum wheels
--New Fusion ZR-1 tires with less than 10,000 miles
--Custom Blue/black interior, all new carpet, seats and door panels, including flames embossed in door panels
--Custom billet IROC-Z embossed shifter knob
--Autometer Phantom gauges (Speedo, Tach, Volts, Fuel, Oil, Water Temp, Fuel Press. and Air/Fuel ratio)
--Pioneer 4x6 inch speakers in dash, Audiobahn 6 inch round speakers with tweeters in kick panels, Polk Audio 6x9 inch speakers in sail panels
--A/C, P/S, P/W, P/L, P/M, Power Seat, T-Tops
--Custom Paint job, paint is in very good condition. Paint does have a chip on passenger door, and rear hatch, but overall looks great as you can see in pics.
--I have pictures...just ask and I will email them to you
I am asking for $6500 OBO....make me and offer, I need to sell this thing ASAP
