2006 items brand new, never used - there are some 2005 items here that are excellent condiion, but used -- all offers appreciated
-- footpeg assembly with heel plate - 1 shift lever side - includes shift lever linkage rod -- $90 (2006-new)
-- clutch lever -- $20 (2006-new)
-- brake lever -- $20 (2006-new)
-- stock blinkers (i have 2 left and 2 right - front and back) -- $10each -- MSRP $48.00 each (2005/06-new)
-- passenger pegs complete with brackets/assembly; all nuts and bolts included (2 left and 2 right available) -- $55 each (2005/06-new)
-- inner fairing pieces between gas tank and fairing -- $20 each $40 per set(2006 and 2005, 2 sets - perfect condition)
-- windscreen -- $25 (2005-some road wear)
-- plastic exhaust pipe heat shield - located on right side above footbrake assemply -- (2 available) -- $20 each
-- exhaust muffler - (2 available - 2005-used 2k miles 2006-new)-- $40 plus $50 shipping UPS/ or pick up at your cost)
-- brake lines - stock front and rear - 2 sets (2005-used 2006-new) -- $10 each set
-- stock rear seat -- $40 -- (2005-never used)
-- chain guards -- (1-2005-used 1-2006-new) -- $25 each
-- left side of lower cowling (perfect condition) -- $100 -- MSRP $195.00 (2005-perfect)
-- knee grips; between gas tank and frame (1 right and 1 left) -- $10 each
-- front fenders - green - perfect condition - 2 available - $45 each; also a 3rd one available with broken tab $25
-- 2005 damaged rear tail, was cracked/shattered in 1 spot, repaired just needs touch up paint, pic available -- also have right middle side panel that needs attention, then a little paint, pic available
If interested please PM or e-mail me at: [email protected]
are the inner fairings the peices that go under the upper...like where the ram air tubes would be on other bikes...im looking for the ones that go between the upper..right and left
yes - the plastic parts that have a foam backing - they sit between frame rail and front fairing under your right and left hands - they cover the wiring - i have them if you need them - i replaced mine with carbon fiber parts
