Year: 2005
Make: Kawasaki
Model: 636
Color: Plasma Blue
The bike was dropped but was saved by the frame sliders. The bike was built to be fast no money spared. As you can see from the parts list... I was a HUGE active member on this forum.
I showed this bike lots of love! Always used Motul motor oil every 3k miles/6 months which ever came first. The way it sits it is completely ridable. I was riding it to and from work, for months!
Since the motor being built only 1,047 miles were put on the motor.
The bad:
*The upper fairing on he right side is rashed.
*right side fairing has a rash.
*clutch cover has light rash.
*right side foot peg is broken and brake pedal bent
*right side rear peg is functional but a little rash
*brake fluid reseivoir cracked
*Rear fairing is rashed up
*Exhaust tips are done. But titanium headers tubing all the way to the rear set are in tact.
*Rear subframe is slightly bent. (but frame is in perfect condition and was verified by professionals)
*right side corner light is cracked
*rear brake light cracked.
*battery dead
The goods:
ELECTRONICS
-DynoJet PC3
-DynoJet Color LCD *not installed*
-DynoJet Ignition Module
-DynoJet Multi function Hub
-DynoJet Quick Shift Button
-Ivans Servo Elimintor
-Jumper Mod (Johnny R)
-Clear Alternatives Euro Style Smoke front turn signal (Only left side)
-Clear Alternatives Integrated Turn Signal Rear Tail Light (damaged)
-Vortex Brake Light switch
TRANSMISSION:
-Factory Pro Shift Star EVO
-Barnett Clutch
-EBC Heavy Duty Clutch Spring
-APE Race Cut "Dogs"
-Lightened Transmission (Racing Connection)
-Hydro Polishing Gears (Racing Connection)
-Vortex Front Sprocket
-Vortex Rear Sprocket
-EK 520 Chain
-DynoJet Shift Rod *not installed*
BOTTOM END
-Hardening & Re Balance Crank
-Carillo Rods
-JE Pistons
-Cometic Gaskets
-NPS Shave / Lightening of Flywheel
-WoodCraft Stator Case (Black w/ Blue skid plate) (blue on skid plate is slightly faded other then that its perfect)
-WoodCraft Ignition Case (Black w/ Blue skid plate)
-Magnetic Drain Plug
-Millenium Technologies Bored Cylinder
TOP END
-Head & Valve Job
-Web Cams
-NPS Adjustable Cam Gears
-OEM Valves & Shims
-APE Cam Chain Tensioner
-Graves Block off plates
-Factory Pro Velocity Stacks
-BMC Air Filter
-Hamaguchi Titanium Exhaust (exhaust ends are bent and damaged, headers to rear foot peg are in tacted)
-Cometic Gasket
MISC.
-Vortex Rearsets (Black) *Not installed*
-Motion Pro Revolver Throttle kit *not installed*
-Driven D3 grips *Not installed*
-Goodridge front Braided Brake line (Black)
-Goodridge rear Braided Brake line (Black)
-Evil Swingarm 6-10" w/underbrace (Matte Black) *stock swing arm available as well*
-LSL Frame Sliders *Right side puck is damaged*
-Outlaw frame plugs *not installed*
-Brocks lowering straps *not installed*
-Puig Double Bubble (Smoked)
$6000 + shipping
Located in Orlando, FL
Will upload pics.
*** This bike at this price should be sold within the week. ***
If its not sold may consider part-out.
