1 - 10 of 10 Posts
2006 zx6r swingarm with LP carbon slider. The left side broke off from a low side. barely moving (under 5 mph). It should be able to put back together. $200 shipped Let me know if you are interested
nothing is impossible... It all depends on how much you want it to fit.
I cant tell you how much fabrication is required. Perhaps someone in the forum could help you with this?
nevermind. If fabrication is required then I dont think I am interested. I was looking for just a quick kind of swap. Thanks though.
--Nate
the fabrication isnt too hard . All you need is a couple shims (as washers) and you have to drill your frame out so that the pivot bolt will fit the older frame. But you also have to have the pivot bolt and hrdware to do this. The 04-04 stuff wont work!
1 - 10 of 10 Posts
