[:+1]Originally posted by liqwidcool375
sit on your bike keep it level,fill it to the brim pay at the pump. You dont even have to get off the bike
That's the only way I fill' er up. Usually put around 3.6 gallon, but I try to fill up at first gas station after the light comes on. The most I put in was 3.9 gOriginally posted by liqwidcool375
I've done this too. In metric-speak, the tank holds 17.0L according to the manual. I've put 17.9L in it before, and have managed to squeeze in over 17L a couple of times, but in all these cases the tank was very empty before, and very full afterwards.Originally posted by nevada
ok you all want the truth??
i ran out. coasted into a station. it was actually still running at idle, but not under any load.
it took....ready for this.....4.818.
and i have on several occasions gotten 4.75, and 4.5. i run several days once the light comes on.
just went to vancouver on sunday, 216 miles, 4.5 gallons.
EDIT: and this is filled up to the TOP. as much as it will take.
i dont recommend this, unless you will be riding it after.
it will heat up and expand, making a very big mess. learned that the hard way.
I get a lot of looks when I do this.Originally posted by liqwidcool375
