i left my bike out for about 2 years, didnt prep it for winter neither. now that i came back to the states, i tried turning the bike on with a booster. i have 2 problems, i hope someone can help me with. after the bikes turns on from the boost, once i take out the booster the bikes dies, this can be cause from the alternator, but the bike is an 03 with 3k miles. can the alternator go bad this early? the other problem i have is that once i got the bike started fuel started leaking form the airbox. apparrently a small hole had developed, and will leak at a higher rate when the i turned the bike on. can i just get a new airbox and this will fix the problem? is all this things normal? thanks for you help.
