1 - 2 of 2 Posts
I need to drain my fuel tank - I believe that a fair amount of rain water got into the tank which is causing my bike to run poorly, if at all; unfortunately I haven't messed with the bike all that much and am unsure where to locate the place to unhook the connection.
I've spent the past hour searching forums/service manual with no luck.
Any help would be much appreciated, and pictures would be awesome if you have any.
Also, I read that I can turn on the bike to allow the fuel pump to remove the fuel once I've disconnected it - I'm assuming that is correct?
1 - 2 of 2 Posts
