Had an off and now the gear indicator is jumping between 3rd 4th and 4th 5th. Any ideas?
It was actually misbehaving before I dropped it, but not this bad so not too sure where to begin.
Just sounds like your gear indicator sensor is off. Probably because you dropped it. If it is broken, it may still be under warranty. Or it could have just gotten dirty or something, so take the sprocket cover off and just spray it with some cleaner.
Mine does it sometimes too - jumps between gears and a lot of times shows as being 1 gear lower then I actually am.
I'm pretty sure its just dirty, but have been too busy to clean it. I would pull the sprocket cover and clean out all the gunk that accumulates in there.
