Has anyone changed a gear or gears on their bike? If so what combination did you use and how much more power or speed did the bike pick up. I am thinking of 1 down (front) and 2 up (rear). Need some feedback on this. Thanks
I did just one down in the front. It really helped with acceleration, but on the highway it would cruise at a higher RPM. Gas mileage got worse too. If you do a lot, or even a moderate amount of highway riding, I wouldn't recommend changing both sprockets. Otherwise I was happy with the change that a simple $20 sprocket brought.
+2 in rear is a subtle difference but combined with -1 in front is awesome. Acceleration is great but makes first gear wheelies really touchy. It will throw your speedo. off alot and you will rev higher than you use to at the same speed. The best thing you get out of it is acceleration and getting wheelies up easier. Cheapest way to go is -1 in front and you can see if you like it. It only takes about 30 minutes to change front sprocket.
I went three bigger on the rear sprocket, which is about the same as 1 down on the front sprocket and it makes a fair difference. If you do it, you'll have fun.
What I mean is my bike now accelerates faster with the standard exhaust than it did with standard gearing and a full Muzzy race system.
i went up 6T in the rear and it riped!! i only lose 10mph on the top side,but who goes 160 al the time. It was GREAT on the track i could out pull the 1000's but 1/2 way down the stright they went past me.
