i would say stock is better for learing...it's not as touchy and gives you a lot more throttle to play with...if you ever rode a geared bike you would notice the gears are short..so if you're doing a wheelie and the bike isn't at balance point you will run out of rpm very fast
if you are going to gear it you could change it alittle like -1 in front or +3 in the back they equal about the same thing....this will help it come up easier but as kin said if u gear it alot you will run out of rpms fast
