1 - 8 of 8 Posts
Looking for some helpful suggestions... What do you guys recommend for improving low end performance as far as gearing changes go? I don't race my bike and would like to still have some decent high end speed. Having never done this, I am pretty ignorant to this subject, so ALL help will be appreciated.
I went down one on the front (14) and up two (42) in the back. Just got my sprockets today as a matter of fact. I will be putting them on this weekend. Top speed will be limited to around 135, but that's still plenty fast for me :)
Lowered the front by a tooth, and left the back the same? 145 would definitely be enough for me. Is the performance increase that much better in the low end in your opinion?
I used to be geared one tooth down in front and two up in back, but recently went back to stock gearing. You can definitely tell a difference in low end power with the lower gearing, and as 4drss said, top speed is about 135mph. The reason I went back to stock gearing wasn't for top speed, though, it was for speeding in the twisties. Seemed like I was always looking for seventh gear on the bike.
On the brighter side, going back to stock gearing hasn't affected the bike's wheelie ability. It takes a little more finesse to get it up, but once I got used to it, it seemed like it was almost just as easy as before. I would recommend going up three teeth in the rear if you are going to change your gearing. By the way, if your sprockets are getting old or show signs of excessive wear, you should replace them as a set and also buy a new chain. If you need help with the install, let me know, I did mine a month or so ago, and haven't had any problems yet:D
1 - 8 of 8 Posts
