anyone know off hand what the stock sprocket sizes are for a 99.
and what changes will be noticed by swapping sprockets out? i havent taken mine apart to look yet.. so im not even sure that i have on the front.. but thre was a 16tooth cs in the storage area when i got it... any input would be helpful and appreciated
stock is 16/43...
i am running 16/45 and can burry the tach in 6th at an indicated 175mph. going down 1 in the front is roughly the same as going up 3 in the back and will give you snappier throttle response but may rob you of some top speed if you go too far.. you'll also be revving higher at any given speed.
ok thanks.. i'll put the 16 back on as soon as i get the chance...it seems to be revving a bit hit in 6th around 80 or so.. atleast in my opinion
