Now in stock and shipping, we have BMC air filters for the 2011 Kawasaki ZX10R. RidersDiscount.com has both styles; BMC street and BMC race air filters for the 4th generation Kawasaki ZX10R on hand and ready to go. Because the 2011 Ninja ZX10R is brand new, availability is extremely limited, especially for the BMC race version. Call Mike at 866.931.6644 x 804 to order before supplies run out!
Gen4 ZX10R Street filters are $63
Gen4 ZX10R Race filters are $67
Both prices include free shipping to any address in the lower 48 states. These are not available on our website, call Mike at 866.931.6644 x 804 to order today!
BMC Air Filters for Kawasaki ZX10R motorcycles provide increased protection while decreasing resistance to airflow as it travels from the atmosphere, through the airbox, and into the combustion chamber. The result is not only an engine that is better protected from road and atmospheric debris, but also increased engine performance since greater air pressure entering the combustion chamber means more fuel can be added at the same time. In other words, if you’re looking for the best possible engine performance and minimum wear due to atmospheric debris, BMC filters can help your realize your goals!
To obtain performance without compromise, BMC ZX10R filters use a special cotton gauze that is soaked with low-viscosity oil to trap particulate matter while allowing oxygen to pass through uninhibited.
BMC air filters for the 2011 ZX10R are available in two different styles: street (left) and the race version with its distinctive yellow marking. The street version has more layers of filtering material to protect engine internals against debris that one could expect to encounter on public roads. The race filter, on the other hand, maximizes engine performance by using as few layers as safely possible to allow an ideal combination between performance and filtering on a racetrack where airborne debris is less likely to be encountered.
By using a special soft rubber chassis, BMC air filters seal against the OEM airbox better than stock so as to allow a greater degree of engine protection. The gauze element itself is surrounded on both sides by an alloy mesh that is coated with a thin layer of epoxy. This epoxy resin protects the filter element from damage; either by debris, backfire and/or other forces it can expect to encounter within the airbox.
Every BMC air filter is made in Italy and packaged pre-oiled so they’re ready to use right out of the box.
All BMC filters can easily be regenerated after any length of time so as to maintain maximum efficiency and protection for your motor. You won’t need to throw yours away because it’s dirty – simply wash as directed and reinstall in your motorcycle!
