So my bikes stock and the headers are glowing on the free way. I have k&n filter, jumper mod and no cat wtf?
I ride 90 mph when ever im on the free way.Originally posted by helo-pilot
what RPM are you riding at and for how long?
lmfao.. my friend saw it not meOriginally posted by hockeynut258
[:TTIWWOP]
Ill prob just buy a kit ecu, and I cant re jetOriginally posted by 1990Scott
I'd have to agree with hoser. You removed the cat which I'm sure is allowing the exhaust to flow better, but at the same time leaned out your fuel mixture. You'll need to rejet. Running lean is bad for engines be in a car or a bike. Running lean is a good way to burn up pistons and valves. I'd get the air fuel mixture checked or put the cat back on and see if the problem goes away.
The cat ceased to existOriginally posted by tweakmon
Clogged/bad catalytic can cause it as well.
your bike also jumps 20 degrees due to know air flow to your radiator or engine causing the coolant to heat up.Originally posted by Donkey
Wow, i never noticed, but i suppose that explains why the bike temp jums 20 degrees celcius when stopped.
Anyone got pics?? that's look sweet.
