Hey GUys I have a problem. My bike decided last sunday that it doesnt wanna run properly. The bike fires up everytime I press the start button no matter what time of day and will run at idle speed for as long as I let it BUT!! BUT!!!!!! As soon as I pull down on the throttle it turns off...well actually if i pull down slowly on the throttle the bike bogs down equally slow then turns off. If I pull down fast it turns off instantly. Has anyone experienced this type of behavior?
Any suggestions. I can check into my carbs, fuel filter and Air filter but I kinda just did all that in late Febuary. I don't mind doing it again of course.
I took a video of my bike just in case my description was lack luster (lol).
YouTube - SoGone12's Channel
:afro:
have you double checked all the vacuum lines? I had a similar issue once and the line that goes from the top of the air box then around toward the front of the bike had come loose under the air box to the carb where the other end was. Not sure if that's what causing this but it's simple enough to check.
