READ: Good things to know about your ZX7-R
i just would like to share some info about the 7R that i've learned from servicing them and owning one myself. this is mainly based off the '96-'03 models, consisting of the N1, N2, and P1-8 bikes..
these bikes HATE TO START HOT!!. they vapor lock. its a fuel system design flaw. a little bit of heat shielding around the fuel lines ( and if you want, raising the float height a bit) tends to resolve this. if you get stuck somewhere on a hot start problem, remove the seat and let it sit.. removing the seat lets some of the trapped heat out from under the tank.
the OTHER hot start issue is low voltage to the starter solenoid. usually about 7 volts or so. it's mainly the wiring and being a piss-poor design.. sometimes voltage can be brought up by cleaning the connectors where the handlebar controls plug into the main harness up by the forks. most times you'll find corrosion there.
-the bikes run HOT! often you'll see a bike with a partially melted, stock plastic fan. when it melts, it'll lock the fan motor up and blow the fuse, usually causing more electrical problems along the way.
Muzzy makes an aluminum fan blade assembly, or you can just wire up the fan to run all the time when the bike is on.
locked-rotor current is typically 5-10 times what the normal running, full-load current is for any electrical motor. (fan pulls 4.3 A)
- these bikes are an electrical engineering nightmare! (at least to me, being that that is what i do..) all the bike's current goes thru the key switch. your bike will typically pull around 15 amps when running and everythings on. the thing is, the switches and connectors are slightly underengineered, and their ampacity (current rating) is lower than what it should be.
- your CDI has a reduced voltage input from a resistor in the key switch's contact block. if that ( 100 ohm) resistor burns up or the wire's solder joint snaps loose (common, unfortunately) you'll have 12 volts everwhere, and no power on the gray wire from the keyswitch harness. that gray wire has less than 12 volts on it (theres exactly 6 volts on it.).
this will cause you to
*not have fuel delivery, (the fuel pump is powered from a pulse fed, SCR "relay". the pulse is source from the #1/#4 sparkplug coil.),
*no spark
*and the bike will have power everywhere, but won't start. it will crank, however.. all day.
- the motors are noisy by nature, and if it slightly resembles an idling diesel, its not the end of the world! you probably just need a valve adjustment or need to bump the CCT out one click.
- if you ever get an e-bay motor, run the engine number thru your local popo. they'll tell you if the number comes up on their system as belonging to a stolen bike or not. you don't have to tell them you already have the motor, just say you're looking at one on the computer and was curious about it before you bought it.
i know a dude that had his whole bike taken by the pigs cuz the motor number came up hot. the bike, (a stunter 636) was fine and legal, but his e-bay motor was stolen, and he didn't know it. when the man blew up the stunt spot, they ran everyones numbers and his shit was seized.
- the '96's (RR model) flatside carbs are jetted horridly lean from the factory to meet epa regulations, but make it vicious on the track. thats why they suck under 4000rpm.
-these bike ARE equipped with a slipper clutch!!
- i think thats about it.. i cant think of anything else, but if theres something i missed, let me know!
i'll list a few common numbers, i'll put more here in time.
Battery, electrical, fuel, ect..
N model:8 amp hour,
P model:10 amp hour
alternator: 14.2-14.8V @ 4000rpm , 30.6A @ 6000rpm
pickup (trigger) coil resistance: 375-565 ohms (typically 460 ohms) (good for ALL ZX bikes with CDI)
primary winding resistance (sparkplug coil): 2.3-3.5 ohms
secondary resistance: 12k-18k ohms
fuel pump pressure:1.6-2.3psi (good for ZX6/R, 7,11, ZZR)
fan ON temp:199-217*F
fan OFF temp: 196-203*F
Fork oil level: 110MM from top +/- 2MM
Fork oil capacity (dry): 495mL +/- 4mL
top cap torque: 11 ft-lbs
allen bolt torque: 29 ft-lbs
stock viscosity recommendation: 5W kayaba oil.. 10W will work fine tho.
ignition info..
black lead:#1/#4 coil
green lead:#2/#3 coil
red lead: both coils GREEN TERMINAL!!!! very improtant.. backwards and you won't have spark.
be safe and have fun!
useful links
"frenching" the taillight (flushmounting..)
http://www.kawiforums.com/zx-7r/129995-how-french-tail-96-a.html
*no spark
N model:8 amp hour,
P model:10 amp hour
ignition info..
useful links
