Float needle issues I've found
Just recently I tried to set the float levels - they proved to be very tricky to set (I've done loads before and not experienced this). If they have rubber tips pry them off carefully and inspect the nipples - I found mine had corroded and had pushed the tips up, thus when trying to set the height they were inconsistent due to the corrosion either dropping out or moving the tip as it dried out!
The symptoms were: poor starting (hot), erratic idle, bogging at wot and snatching at constant throttle - it also makes the 'flat spot' at about 2 to 2.5k worse if you have after-market headers fitted. I changed all 4 valves, set the height to 15mm, removed the K&N*, fitted a standard air filter (without the mesh) and - voila! Fixed. Bike is a 1998 ZX-7R with 20,000 miles.
I hope this helps someone out who may be chasing their tales in frustration.
*I have found that the K&N accentuated the poor running issues and it needed cleaning far more frequently than I thought was practical.
