Originally posted by prs
Don't know if you've seen the other posts Nevada but I and some others also had that swaying problem. Mine started after I removed the damper and reinstalled it. So I removed it again, made sure no cables were pinched (one was pinched) and reinstalled. No problems since and I've taken it off and reinstalled several times since then.
yeh ive read as many as the others as i could.
it was told to me the way to fix it was remove it, and reinstall it.
i called bullshit, as that had nothing to do with anything.
i indeed did have to take it off, so i could loctite the bolts.
NO CHANGE once it was reinstalled.
after i posted that earlier today, i called GPR.
i found out what the problem is.
i will be fixing it tomorrow.
basically the little arm, that come towards the tank. that needs to be flush or slightly higher than the post clamp it sets in.
i know that mine is slightly lower, and was the first time i put it on.
hopefully that fixes it.
