1 - 20 of 31 Posts
Guide to How-To Navigation.. New and Improved
****under construction****
i am trying to "group" these as best as i can. transmission related stuff, lighting related stuff, FI light stuff and so on.. but i have ADD and i make no promises on organization.
you owe anyone who's info you use either rep points, money, or alcohol and/or titties. this is saving you a shit ton of money and taking money out of my pocket as well, since this is what i do for a living.
noobs: your reps are neutral for a while so.. i'll just take money instead..
the authors of this information can not be held liable for damages due to mechanical ineptitude, incompetence, negligence, workmanship (or lack thereof), damages to property,or physical harm to yourself or others. furthermore, I am not responsible for the accuracy of the information contained herein. use at your own risk. (except my info. it's the shit. :D)
General Powertrain
How to..Understand octane
*http://www.kawiforums.com/two-wheeled-discussion/119384-octane-what-ok.html
How to.. Understand oil viscosities and ratings
*http://www.kawiforums.com/oil-lubri...lp-understanding-oil-weights.html#post2424094
How to..WINTERIZE your bike
*http://www.kawiforums.com/how-tos-faqs/167801-how-winterize.html
*http://www.kawiforums.com/ninja-250...interization-question-answer-thread-250s.html
How to..sync the carbs/throttle bodies
*http://www.kawiforums.com/how-tos-faqs/68740-syncronize-your-throttle-bodies.html
*http://www.kawiforums.com/how-tos-faqs/101901-carburator-synchronization-made-kinda-simple.html
How to..adjust carbs
*http://www.kawiforums.com/how-tos-faqs/47957-universal-float-setting-any-carburetor.html
*http://www.kawiforums.com/zx-7r/147241-fuel-screws.html
*http://www.kawiforums.com/ninja-250r/105901-raising-needle-jets-mod.html
How to, change your spark plugs
*http://www.kawiforums.com/how-tos-faqs/151705-how-replace-spark-plug-07-08-zx6r.html
*http://www.kawiforums.com/how-tos-faqs/134255-how-change-spark-plugs-06-636-a.html
How to..change your oil
*http://www.kawiforums.com/2003-2004-zx-6r/100506-changing-oil.html 03-04 6R
*http://www.kawiforums.com/how-tos-faqs/29335-change-your-oil-2005-6r.html 05 6R
*http://www.kawiforums.com/how-tos-faqs/141439-07-08-oil-change-ultimate-guide-pic-intensive.html 07-08 6R
*http://www.kawiforums.com/ninja-250r/113982-2008-ninja-250-oil-change-procedures.html 08 250
*http://www.ninjette.org/forums/showthread.php?t=10780 250
*http://www.kawiforums.com/how-tos-faqs/100554-how-change-oil-your-ninja-250-video.html 250
How to..burp your oil filter
*http://www.kawiforums.com/how-tos-faqs/41248-burping-your-baby-after-oil-change.html
How to.. cross reference an oil filter
*http://www.calsci.com/motorcycleinfo/FilterXRef.html
How to..Change/flush your coolant system
*http://www.kawiforums.com/ninja-250r/137893-diy-coolant-flush-refill.html#post2202148 (for 250R)
How to..bump your CCT
*http://www.kawiforums.com/how-tos-faqs/95636-how-adjust-factory-cct-636-a.html
How to..do a valve adjustment
*96-03 ZX7R valve adjustment
*http://www.kawiforums.com/zx-7r/130315-valve-adjustment.html (also for the 7R.. but everything translates to other bikes)
How to..do the Kleen air mod
*http://www.kawiforums.com/how-tos-faqs/101454-07-08-zx6r-kleen-air-mod.html
*http://www.kawiforums.com/how-tos-faqs/120477-how-kleen-air-mod-05-06-zx6r-complete-updated.html
*http://www.kawiforums.com/how-tos-faqs/132704-07-08-6r-kleen-air-mod-video.html
*http://www.kawiforums.com/ninja-250...-air-system-hoses-plugging-holes-08-250r.html
*http://www.kawiforums.com/how-tos-faqs/69495-remove-ca-smog-crap-pair-kleen-mod-05-06-zx6r.html
How to..replace shift forks and do trans repair
*http://www.kawiforums.com/how-tos-faqs/118245-05-06-zx6r-rr-change-out-shifting-forks.html
*http://www.kawiforums.com/zx-9r/162213-1999-zx9r-tranny-swap-2000-a.html
How to..install an aftermarket shift star
*http://www.kawiforums.com/how-tos-faqs/87288-factory-pro-shift-kit-05-06-zx6r.html#post2200115
*http://www.kawiforums.com/how-tos-faqs/85968-installing-factory-pro-evo-shift-star.html
How to..replace your clutch
*http://www.kawiforums.com/how-tos-faqs/101897-how-replace-your-clutch-plates.html
*http://www.kawiforums.com/how-tos-faqs/21772-how-install-clutch-kit.html
*http://www.kawiforums.com/how-tos-faqs/47954-clutch-assembly-tips.html
How to.. remove your cat ( this is illegal, mind you, but its not like the exhaust police will probably get you unless you're in Nazi cali or virginia)
*http://www.kawiforums.com/how-tos-faqs/157508-dyi-cat-removal-zx6r-2007-2008-a.html
How to..Bypass your tip-over sensor
*http://www.kawiforums.com/2007-2008-zx-6r/164792-vehicle-down-sensor-bypass-instructions.html
Driveline Maintenance
How to..make your own chain rivet tool
*http://www.kawiforums.com/how-tos-faqs/121549-diy-chain-rivet-tool.html
How to..clean/replace your chain
*http://www.kawiforums.com/how-tos-faqs/129412-clean-your-chain-fast-easy-really-clean.html
*http://www.kawiforums.com/how-tos-faqs/132762-how-replace-your-chain-w-pics.html
How to..remove sprockets
*http://www.kawiforums.com/how-tos-faqs/107100-front-sprocket-how-my-05-a.html
*Get your nut off!
* http://www.kawiforums.com/2007-2008-zx-6r/157760-how-remove-front-sprocket.html
How to..replace wheel bearings
*http://www.kawiforums.com/two-wheeled-discussion/139263-get-your-bearings-right.html
Performance, tuning and modification
How to..calculate various engine numbers with advanced math
*http://www.kawiforums.com/how-tos-faqs/143690-random-engine-related-formulas.html
How to..start understanding and size a turbo system
*Basic turbo info
How to.. understand combustion so much it'll stop making sense.
*http://www.kawiforums.com/how-tos-faqs/164669-combustion-ultra-super-uber-depth.html
How to..do the jumper mod
*Jumper Mod
*http://www.kawiforums.com/2005-2006-zx-6r/147833-jumper-mod.html (different from the one above)
*http://www.kawiforums.com/how-tos-faqs/43549-wiring-mod-zx6r-zx6rr-2005-06-a.html
How to..install X-TRE
*http://www.kawiforums.com/how-tos-faqs/154376-07-08-x-tre-install-how.html
How to..find a Power Commander Map
*http://www.kawiforums.com/two-wheeled-discussion/153553-power-commander-map-database.html
Discussion Starter · #2 · (Edited)
Pg.2 -"Why does......", and more how-tos
General Chassis, Body and Suspension
How to..remove the front tire and/or rear and/or axle
*http://www.kawiforums.com/how-tos-faqs/147324-how-remove-front-wheel.html
*http://www.kawiforums.com/how-tos-faqs/38467-remove-your-wheels-put-them-back.html#post38467
*http://www.kawiforums.com/how-tos-faqs/20788-how-remove-front-axle.html
*http://www.kawiforums.com/2007-2008-zx-6r/158779-how-remove-front-wheel.html
How to..bleed your brakes/change fluid
*http://www.kawiforums.com/how-tos-faqs/128126-easy-peasy-brake-bleeding.html
*http://www.kawiforums.com/how-tos-faqs/121283-how-bleed-brakes.html
*http://www.kawiforums.com/2005-2006...um-pump-brake-bleed-kit-now-how-do-i-use.html
*http://www.kawiforums.com/how-tos-faqs/159242-brake-bleeding-fluid-change-procedure.html
*http://www.kawiforums.com/how-tos-faqs/174401-brake-fluid-change-bleeding-tutorial.html#post2397387 (video)
How to..understand/set suspension
*http://www.kawiforums.com/how-tos-faqs/108982-suspension-help-trouble-shooting-learn-lingo.html
How to..change your fork seals
*http://www.kawiforums.com/how-tos-faqs/99425-fork-seal-replacement.html
*http://www.kawiforums.com/how-tos-faqs/101898-how-replace-fork-seals-inverted-forks.html
*http://www.kawiforums.com/how-tos-faqs/184673-how-dismantle-inverted-forks-pic-heavy.html
How to..install lowering links
*http://www.kawiforums.com/ninja-250r/130738-diy-installing-roaring-toyz-lowering-links.html
*http://www.kawiforums.com/how-tos-faqs/56648-how-lower-your-bike.html
How to..chop/shorten your kickstand ( for lowered bikes)
*http://www.kawiforums.com/how-tos-faqs/152234-07-08-shorten-your-own-damn-kickstand.html#post2118308
How to..make a fender eliminator
*http://www.kawiforums.com/2009-zx-6...-fender-eliminator-six-bucks.html#post2104593
How to..hide/relocate your rear brake reservoir
*http://www.kawiforums.com/2007-2008-zx-6r/103267-how-relocate-rear-brake-reservoir.html
How to..repair your plastics
*http://www.kawiforums.com/how-tos-faqs/143681-fairing-repair.html
*http://www.kawiforums.com/how-tos-faqs/156235-how-fix-your-plastics-pic-intense.html
*http://www.kawiforums.com/how-tos-faqs/130680-how-paint-repairing-fairings.html
How to..paint your windscreen
*http://www.kawiforums.com/ninja-250r/114096-how-paint-tint-your-windscreen.html
How to.. tint your.. whatever. tail, lenses, ect.
*http://www.kawiforums.com/2007-2008...urn-signals-brake-lights-ect.html#post2139172
*http://www.kawiforums.com/how-tos-faqs/101426-how-tint-you-headlights-taillights.html
WHY WHY WHY !!???
Why cant..I post a thread anywhere here?
*http://www.kawiforums.com/newbie-corner/165104-how-come-i-can-only-post-newbe-section.html
Why Does.. my turnsignals flash at a retarded rate with a new LED taillight?
*http://www.kawiforums.com/zzr600-zx-6r-old-school/164407-signal-light.html
*http://www.kawiforums.com/2009-zx-6r/158367-led-signals-slow-flashing.html#post2215895
Why Does.. My bike make a machine gun/buzz/rattle sound when i try to start it?
*http://www.kawiforums.com/how-tos-f...ery-stuff-jumpstarting-myths.html#post2131958
Why did..a piston come thru my lower case?
*http://www.kawiforums.com/two-wheeled-discussion/163018-why-engines-fail.html
(more how-to...)
General Disagnostics
How to.. know what code numbers are what actual problems
*http://www.kawiforums.com/2005-2006-zx-6r/120244-trouble-code-list.html
How to..pull trouble codes
*http://www.kawiforums.com/how-tos-faqs/134059-how-pull-fi-codes.html
*http://www.kawiforums.com/how-tos-faqs/53334-03-04-zx6r-r-how-perform-self-diagnosis.html
How to..clear trouble codes
*http://www.kawiforums.com/how-tos-faqs/126425-clearning-f1-code.html
How to..do the FI light "fix" (or exhaust servo mods)
*http://www.kawiforums.com/how-tos-faqs/105518-how-fi-light-fix.html
*http://www.kawiforums.com/how-tos-faqs/101201-how-get-rid-servo-motor-chatter.html
*http://www.kawiforums.com/how-tos-faqs/120455-another-diy-fi-light-fix.html
How to..make general diagnostics on your bike
*http://www.kawiforums.com/how-tos-faqs/101896-basic-engine-health-insdpection.html
General Riding tips, techniques and questions
How to..Become a better rider
*http://www.kawiforums.com/newbie-co...s-street-riding-minor-things.html#post2336264
*http://www.kawiforums.com/how-tos-faqs/163353-how-not-crash-so-much-pt-1-a.html
*http://www.kawiforums.com/newbie-corner/30940-good-riding-tips.html
*http://www.kawiforums.com/newbie-corner/103105-if-you-have-never-ridden-motorcycle.html
How to..Choose What line to pick on a rainy day
*http://www.kawiforums.com/two-wheeled-discussion/164193-rain-riding-position.html
How to..select the right fuel
Racing/competition related
How To.. Get startin in road racing
*http://www.kawiforums.com/road-racing/125753-how-go-road-racing.html
How to..Prepare for a track day event
*http://www.kawiforums.com/road-racing/98888-how-prepare-track-day.html
How to..Get started in drag racing
*http://www.kawiforums.com/drag-racing/72391-best-technique-basics-beyond.html
How to..Install a 6R shock on your 250R
*http://www.kawiforums.com/ninja-250r/147490-zx6r-rear-shock-sorta-howto.html
How To..general 2009 ZX6R shit
*http://www.kawiforums.com/2009-zx-6r/153357-09-zx6r-how-tos-faqs.html
How to..general 07/08 ZX6R shit
http://www.kawiforums.com/2007-2008-zx-6r/149788-full-07-08-how-compilation-thread.html
How To.. Build a rear stand
*http://www.kawiforums.com/two-wheeled-discussion/162377-250-project-day.html
Pg.3 *reserved for future additions*
Chassis electrical and lighting
How to..get schooled in electrical theory, battery stuff, troubleshooting
* http://www.kawiforums.com/how-tos-f...al-crap-battery-stuff-jumpstarting-myths.html
* http://www.kawiforums.com/two-wheeled-discussion/189100-batteries-will-explode-edition.html
*http://www.kawiforums.com/how-tos-faqs/129656-fault-finding-flowchart-electrical-systems.html
How to.. get your turn signals to stop flashing all retarded like.
*http://www.kawiforums.com/how-tos-f...-when-replacing-turn-signals.html#post2242768
How To.. make your own LED Taillights
*http://www.kawiforums.com/two-wheeled-discussion/169700-diy-led-turn-signals.html#post2319911
*http://www.kawiforums.com/zx-7r/170707-custom-led-tail-92-zx7.html#post2335522
How to... figure out what bulbs you have
*http://www.kawiforums.com/2007-2008-zx-6r/103887-official-07-08-zx6r-complete-bulb-size-thread.html
*KAWISPEED - View topic - Identify those bulbs
How to..do an HID kit or system
*http://www.kawiforums.com/how-tos-faqs/128127-how-install-xebrite-plug-n-play-projectors.html
*http://www.kawiforums.com/how-tos-faqs/43086-how-hid-projector-retrofit-636-a.html
*http://www.kawiforums.com/how-tos-faqs/92035-hid-install-sold-allenchang-2006-636-a.html
*http://www.kawiforums.com/2009-zx-6r/137801-how-hids.html
How to..do a dual headlight conversion
*http://www.kawiforums.com/how-tos-faqs/83500-dual-headlight-configuration-updated.html
*http://www.kawiforums.com/how-tos-faqs/133787-dual-headlight-kit-installation.html
*http://www.kawiforums.com/how-tos-faqs/131626-detailed-dual-headlight-conversion.html
How To.. change your gauge lighting
*http://www.kawiforums.com/zx-7r/129348-led-gauges-cheap-how.html
*http://www.kawiforums.com/how-tos-faqs/32331-changing-your-backlight-color-your-gauges.html
*http://www.kawiforums.com/how-tos-faqs/77169-changing-your-gauge-color-v-old-school-zx6r.html
*http://www.kawiforums.com/how-tos-faqs/102409-how-07-08-gauge-color-change.html
How to.. change you MPH to KPH, C to F, set clock..
*http://www.kawiforums.com/how-tos-faqs/112527-setting-clock-e9.html
*http://www.kawiforums.com/how-tos-faqs/142397-setting-clock-07-zx-6r.html
*http://www.kawiforums.com/how-tos-faqs/129999-mph-kph.html
How to..replace your battery
*http://www.kawiforums.com/how-tos-faqs/106668-how-change-battery-05-06-zx-6r.html
Discussion Starter · #4 · (Edited)
Pg.4 *Reserved for future additions*
and god forbid i am alive within 10 years, page 4 for future expansion
IN ADVANCE, please forgive me. I cant find (search) anything relating to replacing the Brake Pad on an 1st Generation ninja 250r. My ride: "Ninja, 2004,250R". Plenty 'how tos &vids' for the '08+ Ninja 250R's, but nothing for our Old and forgoten 1st Gen Ninja 250R's.
Please help, and TIA, Al
[email protected]
should be the same? been a long time since i did brakes on a 250.. if i find a how-to i'll post it.
Is it just me or is this thread really hard to navigate through...
******>>>>>J/K<<<<<***** (<--better?)
Thanks for the awesome section. I have another How To on fairing repair if you want to add it. I wrote this one up last year (lots of pics) and it works very well.
Discussion Starter · #11 · (Edited)
i will amend.
if it IS kinda hard to navigate tho for real, let me know. maybe i can fix it.
thanks for the links. rapes dispatched
i will amend.
Navigation works perfectly fine with this and is faster then doing a search. It's nice having these How To's right at your fingertips for quick access. Did you actually review all the threads that you have added to make sure that they are all good? I know you are probably doing this in your free time and it will take a while to review all the threads, but it will be well worth it in the end to know that these threads have all the information people will need and not have to ask questions that have already been answered. Within the next few weeks I should have a few more write-ups that will work perfectly in here.
Things to come ('03 ZX-6R):
-chain and F/R sprocket replacement and adjustment
-valve adjustment
-spark plug change (will be using the same pics from the valve adjustment)
-throttle body sync using home made sync tool
-possibly fork seal/dust cover & oil change (depends on how much I can afford)
I will send you the information when I have all of it done so that you can add it to this section.
Discussion Starter · #14 ·
OP
By yumadtho at 2010-11-04
*bows*
-valve adjustment
right on.
lol ya. i went thru every.fucking.link. this took me days to compile. i spent a few hours a night for almost 2 weeks going thru shit. i found alot of them i initially looked at to be total shit. i tossed probably 20-40 links from my list since they sucked or turned into a flame war or something.
i'm down for all you wanna post up man. let me know and i'll get it in there.
J/K whitehendrix, thanks for the awesome section. I have another How To on fairing repair if you want to add it. I wrote this one up last year (lots of pics) and it works very well.
Easiest way to do it, assuming you know what you're looking for, is to just hit control + F and start searching the page for key words. If the info's here you should get it quick, and if it's something that should be here and isn't you can ask ****** to throw it in! :thumbup:
Lol, I know. That's why I put J/K right after that. I'll go back and edit it so that it stands out more :p. Thank you though and hopefully someone who was unaware of ctrl + F will be able to use that function as well.
Hi Whitehendrix Could you please give me some advice as to how to remove the ingition switch on my zx11 2000 mod. I'm a daily rider and the other day at work the key would not start up the bike. I checked the battery and it was fully charged. This has happened a few times before. The key would not bring up the ignition lights. After playing with the key a little the ignition lights have come up and I've been able to crank it up. This time however no go. Anyway I looked at my manual and it shows no info on removal, sad 'cause here in Austalia locksmiths charge an arm and a leg! and I want to avoid talking it to them. Anyway I got as far as removing the steering but I can't see any allen key bolts or nuts to remove the ignition off the steering. Could you please spare a little time to tell me how to do it. I go back to work in 5 days and I am desperate. Thanks mate. Mick.
Discussion Starter · #20 ·
thanks STi
theres a few links that are not KF internal threads..
as far as direct questions to me, it's probably best to search, start a thread or PM me directly.. chances are i will miss it if it's in here as i come back here every few months to update.. it'll be too late to help you by then.
1 - 20 of 31 Posts
