1 - 10 of 10 Posts
Banned
Put RXP in your fuel tank due to water in the fuel because of Ethanol. You can get RXP from Auto Parts Stores.
Fixes it right up.
yep. or any water remover. seafoam will work to.
Banned
The RXP is the best stuff I've tried. It cleans injectors, removes (more like bonds with and makes it combustible) water, and de-carbonizes your combustion chamber. Only cost $7 at Autozone or other parts stores and treats up to 25 gallons fron a tiny 2.5oz bottle.
yea seafoam does the same. the rxp sounds diffent though cause i belive the seafaom is a 7oz bottle which treats 25 gallons.
Banned
Discussion Starter #6
I know most Auto parts stores (I get mine from AutoZone, Pepboys or O'Reilly) carry the RXP. It treats 25 gallons also like the Seafoam.
Banned
Discussion Starter #8
Did you do anything to the bike; work on it or something? How old is you gas in the tank? Was it running good before it started acting up? If so, change you gas and add some RXP.
Banned
Discussion Starter #10
Nothing as good as RXP or Sea Foam but you can try Heet or Chevron Techron Fuel injector cleaner. A little bit of 70% Isoprpyl Alcohol works good at removing water also.
1 - 10 of 10 Posts
