I've been following this forum for a while now and has been very helpful. Got a issue with my headlights. The low beam will is on and works fine all the time, the high beam when turned on stays on for a few seconds then begins to flicker and then flickers a little faster before turning off. I have even had where I turn my bike on with the high beams on and the high beams work fine but low beams dont work at all. It has to be a bad connection or misrouted wire, or ground issue right? Any help would be appreciated. I dont know where to start.
