This weekend I installed amber led clusters in the corners of my headlights and integrated them into my turn signals. They look great! The only problem is that even though I was careful not to get any plastic shavings inside the light it happened anyhow. What is the easiest way to get the headlight covers off? I figure once I do that I will go ahead and change the bulbs with some bright whites also. Perfect excuse. The wife will never know what hit her! [}:)]
Tape a rag on the end of a long screw driver, then reverse (sticky side out) some masking tape around the rag. That should work. Could also try to blow out with some air (ie. compressor, air in a can).
BTW, the Hyper Whites look bad ass!
