Originally posted by wharthog3II<br>I got mine at hoyttech.com and it works really well. It isn't a stand alone unit. It plugs into my Cannon, the same way you would connect the Cannon to the VCR. It records sound too. I took a morning commute video if you seach my posts. I think it is in Pictures and Movies titled SD Morning Commute. If you have any questions or want more info let me know.
[:+1] I also got the Hoyttech (HC Pro) which is a Sony unit. It works great, and comes with mounts for helmet AND bike (or wherever else you want it mounted). Not cheap, but the vid quality is very good.
http://hoyttech.com/index.cfm?fuseaction=product.display&Product_ID=279
The media to which you save depends on what you plug the camera into - mine (like Whart's) goes into the ANALOG a/v inputs on a Canon Elura 100, which has the option of saving to DV tape or SD card. The saves to the card are lower res, and limited in length, depending on the size of the SD card. The DV tapes are simple enough to use, and give very good quality.
No matter what you decide, make sure your camcorder has ANALOG A/V inputs, or you won't have any way to connect the cam to it.
You may find that mounting the cam on the helmet (while it does give you the rider's perspective) is a bit distracting; every time you turn your head to check over your shoulder or the mirrors/instruments, the image jerks right along with your head - very dizzying effect. If you go that way, be prepared to do some editing...lol.
