1 - 20 of 20 Posts
how do i clean the liner of my helmet? can i just take it out and put it in the washer, or can i only use the sprays that i see in catalogs? it's a shoei RF900. its been almost 2 years since i got it, and i think it needs to be freshened up a bit.
I would not wash it in a machine. If anything, I would hand wash it.
I checked a Shoei user manual just now, and i must say, those are poorly laid out. Nothing about cleaning the lining, just the outer shell and faceplate.
-Flash
Most people use a mild soap/water.Then let it air dry completely..If i'm not mistaking the RF900 doesn't have a removable liner.So you have to hand wash the inside/rise good and let dry.
Oh and if you wash/rise the inside of the helmet you can dry it with a hair blow dryer. But NO HEAT ! Use it on cool setting only. You don't want the inside of the helmet staying damp and possibly getting mildew.
-Flash
Wear it in the shower and let it dry good! That's what I've always done and never had any problems. Just shampoo your hair, put the helmet on and move it around a bit, then rinse thoroughly.
Always nice to have a clean smelling helmet:)
Use shampoo to clean it. You'll have to let it dry for a day or so, but when you're done it'll be so fresh and so clean clean....
Just don't over do it, you'll get a feel for how much shampoo to use as you'll see that brown nastiness that came off your own scalps make its way down the drain. When you stop seeing brown, you know it's relatively clean. Rinse, repeat then let it set for a day to dry.
Or you could just buy an Arai with a remove-able liner, and it'd be a hellova lot easier. [:p]
You guys really wear your helmet in the shower? Never heard of that.
I think I'll stick to my method. LOL
-Flash
i just washed mine out yesterday. took out the liner and hand washed it in the sink. i let it air dry outside overnight, then sprayed some febreeze in it. good as new.
Just half fill the bath .. chuck it in *gently* .. give it a good scrub with some shampoo and hang out to dry ... try not to look at the colour of the water before you empty it .. or maybe thats just mine lol
Am I the only one that actually wears their helmet in the shower? I figure kill to birds with one stone, lol!! I started doing that years ago with my dirtbike helmets then when it came time to clean the streetbike helmet I figured, heck why not....
Shower with your helmet. I'v egot to say that is the funniest thing I've heard on the to do list. Gotta try it!
Maybe we can get Ashley to demostrate this technique for us.
Buy an Arai or a Shoei, they have removeable liners ;) use rubbing alchohol on the inside of the chin bar to get rid of that stinkie halatosis smell you've been known to produce.
If you ever sneeze in your helmet ::GAG:: be sure to get the rubbing alchohol on the double!
LOL
Now that's funny.
1 - 20 of 20 Posts
